I have used the search button with regards to this topic and I haven't found the answers I am looking for
I have a set of HRC throttle body trumpets and I am wondering what they are going to do for my setup?
I have all the free mods, turn one airbox and snorkel, banzai exhaust, and a yoshimura ems controller. What would these trumpets do for me? Are they going to improve power across the board? Shift the current power band higher? KIll low end but make more top end? Would I be better off with the stock ones? Switching the placement of the stock ones?? thanks in advance guys
Looks like they're both the same height.
It's hard to tell, but I'm guessing they're the short length?
Here is some information obtained on another forum where dyno testing was done with varying intake length combinations.
"I spent 2 days at the dyno testing all combinations of velocity stacks (2 short, 2 long, 1 short up front, 1 short on the rear) on both SP1 and SP2 throttle bodies.
We found on both SP1 and SP2 is there was no power to be gained by going to 2 short, and no power to be lost by having 2 long. What we did change was the mid range.
In both cases having the long on the front and short rear gave us the best curve (opposite from normal).
A nasty dip would show up in the 6-7K range with two short. We didn’t see much improvement anywhere by having two long but it didn’t hurt the top end.
We (and I have heard from others who tested with the same results) believe the only reason Honda uses a short stack in the front was due to limited space in stock airbox.
Testing was done on a high comp engine with head work, cams and a full exhaust. I have not tested on a stock engine but believe the results would be very similar."
i belive Damon's tested in this was done on a open airbox and that changes any stock box comparo right out the window
get ahold of thorsten or Horde if you are seriously looking for real answers
