1 - 11 of 11 Posts
Is anyone using it?..I have ordered from Scott..
I want to know what is the different feel when using it?
I'm running them. I really didn't feel a difference basically they're just lighter then standard plates. You will notice its a pain to find nuetral until you break them in. After about 50-100 miles you'll be good. I would do alittle street riding with them 1st before you headed out to the track.
Hmm, that funny..they stated it will increased in pickup...
Your just lightening up the rotating mass in the clutch basket. In a sense its the same as switching from a 530 chain to a 520. Your losing some weight but when you hammer on the gas could you really tell the difference between the two? You might notice a difference with the hyperplates I'm just telling you that I didn't. Either way its a good buy cause your shedding weight and losing weight is the best mod you can do to the 51
Discussion Starter · #5 ·
To lose some weight on the RC is way expensive..well my next buying will be slipper clutch from Europe sellin at 480 euro..
I haven't got around to installing my Hyperplates yet.
It took three months (at least) to even receive mine.
I talked to the owner of manufacturer last year and a German company bought out his entire inventory.
He said it was a love/hate relationship, that while he made a lot of money, he now had to re-stock his inventory from scratch. Hence the delay.
Speaking of rotating mass, I'll be checking price/availability on Durbahn's clutch basket when I get a chance.
It's about 2-2.5 lbs. lighter than stock. That's a large change, so shifts should be much better I'd think.
Also for the racers, he also makes a lightweight racing alternator and flywheel kit.
Now that will definitely allow the engine to rev quicker.
Before the thought occurs, he flatly states it won't work on the street as it doesn't generate enough output at street rev levels to charge the battery with lights on.
At the higher revs used on the track (no lights of course) it charges fine.
Now if he could somehow meet the two halfway and lighter flywheel for street use, I'd be interested.
Discussion Starter · #7 ·
Sub keep me informed of the price..any others source making clutch basket?
Discussion Starter · #9 ·
So far Scott have'nt reply me back. I was informed that he only have full carbon airbox & he's waiting for hyper plate to arrive so that he can shipped it over to me...As for Brett owner of Turnone will be back in Australia by 25 Aug..
If you're planning on using Hyperplates with a slipper clutch, be sure to inspect your plates more frequently.
I say this only due to other message board threads where a fellow damaged his clutch when using this combination.
The slipper clutch overheated the Hyperplates and they started disintegrating.
Discussion Starter · #11 ·
Ok, in that case i will skip the slipper clutch for time being...anything to make the RC51 competive with other new model?...Used for track & road worthy...i have ordered turnone airbox only from Scott, not sure to get the snorkel also....he also selling the ceramic bearing..should be gd on the front wheels.
1 - 11 of 11 Posts
