1 - 20 of 75 Posts
Yea yea I know... I usually answer these types of questions, but my fuel pump isn't working I don't have an SP2 Service Manual handy, I only have the SP1 Manual which brings me to my first question:
1. Is the wiring diagram for the SP1 the same as the SP2 in regards to the fuel pump, bank angle and relays etc?
2. Isn't the middle wire on the fuel pump plug the only hot one?
I let the fuel pump sit dry for a few months and I am afraid that it has locked internally as I have had this happen before with the nasty ethanol fuel we have to use. Got lucky and just had to beat on the fuel pump a bit with a rubber mallet and it started working again. but faaack I don't want to take that pump out of the tank again so I want to confirm the electrics are proper before going after the fuel pump directly.
I believe the sp1 and 2 are wired the same as far as fuel pump and kill logic go.
I just went over exactly this with a guy earlier today
First thing to do is verify the engine stop relay is working. Just hold the relay in your fingers and feel for a click when you toggle the kill switch
If the engine stop is clicking, do the same with the fuel pump relay. Check for a click on, then click off a few seconds later
If the engine stop clicks with the kill switch but the fuel pump doesn't, check that the wiring to the ecu is in good shape, the brown/black is provided a ground by the ecu to run the fuel pump relay.
If both relays are clicking and you have verified 12vdc on the black/white wire, chances are it's the pump.
The power to the fuel pump comes off the fuel cut relay on a brown
The low fuel sending wire is a brown/black.
Hope this helps
Well shit... Fuel Relay does not click (I have swapped all the relays and all of them click when used as engine stop relay.)
Fuel Relay:
Brown/Blk wire to the fuel relay is 11.9v hot from the ECU with the key on.
Brown wire from the relay never goes hot
Both Blk/Wht wires to the relay are 13v+ hot
At the fuel pump:
middle Brown/Blk wire is 12V
Brown wire is cold
Looks like I am gonna be up awhile... I had forgotten how much I hated working on these things and even more how much I hate looking at schematics.
Mike, if the brown/blk is hot then the ecu isn't giving the relay a ground signal. It's got 12v on it from the black/white wire on the other side of the coil.
If you force this brown/blk to ground the pump will run.
Unplug the ecu connectors and check for poor connections or corrosion on all grounds and that brown/black
If all checks out, try a known good ecu.
that's too bad. the ecu is the last contact in the logic controlling the fuel pump so if grounding the brown/black lights up the pump, you've got something going on between the ECU and ground.
i would double check all the grounds anyway though. just set a meter to continuity and probe all the grounds in the ECU connectors to battery negative.
fortunately sp2 ecus are pretty plentiful, i'm sure you won't have trouble finding one.
I feel your pain. Spent several days squinting over the wire diagram only to luck into cause of problem. Was pushing wires at rear of tank into place when ground from PC3 popped out of crap crimp job I performed. Repaired it and bike fired right up after I had run tests on half the freakin circuits. Pretty much been the way I have learned electrics. And why the hell can't we have a quick disconnect for the fuel lines on this beast? Hate dealing with the banjo fitting for the fuel feed! Good luck Mike.
It's because of good threads like this one, that guys like me can possibly avoid an unnecessary chore removing the pump. I've read more than a few threads where guys have gone straight to the fuel pump before checking the chain of command: wiring.
I hope your ECU isn't fried LDH, good luck.
My takeaways....
1) "I need help"....LDH has finally succumbed to the pressures of knowing it all.:kiss: Admitting you need help is the first step to recovery.:grin2:
2) I concur that removing the fecking tank sucks donkey balls.
3) Threads like this although hurt one of our kindred spirits, most assuredly will help someone else from doing the same shit.:nerd:
I hope finding a good used unit won't be a problem.
https://www.ebay.com/itm/00-01-HONDA-RC51-SP1-ECU-COMPUTER-CDI-ECM-CONTROL-ELECTRONIC-UNIT-BLACK-BOX-3348-/282232422870
Discussion Starter #15
The real issue is I had not taken into consideration that the ECU might be bad. Simply was not expecting that and had already done all the troubleshooting work specifically excluding that condition before I posted here.
In retrospect it should have been a high probability even before I started to repair the wiring harness.
Link to site (French) with N. America SP1/SP2 Service Manual (Manual is in English).
Extract from the Zip file and rename.
This is the same manual that used to be obtained from the old RC51.info site (which has been highjacked by a porn site apparently, much to my surprise :surprise:)
Honda RVT 1000 R SP2 Service manual - Download service / repair / owner / maintenance manuals, motorcycle tutorials, microfiche
1 - 20 of 75 Posts
