1 - 16 of 16 Posts
so my luck .all bad i ordered all new parts , to have the water pump and every seal in the right crankcase cover replaced , even over night one part , called in sick to make sure i got everything to the shop to be done to day , then my buddies called from the shop and told me bad news . as the bearing was being pressed out , it broke apart and the race is seized in the case , they tried to heat it up nothing , so they told me to come get it wont work , dam a new case is $170+
Oh man...
Bad news.
I guess it's beyond a slide hammer/gear puller?
its very small would not work :( im going to pick it up tomorrow and see what i can do , maybe take it to a machine shop :eek: turns out a new one is $170+
The bearing is a 6200 type, which is 10mm I.D. x 30mm O.D. x 9mm Width.
That doesn't give much room to work, but I wonder if you can use a dremel tool with a cutting disk to very carefully make cuts into the race and to allow breaking it apart.
Either that or a bearing puller attachment with slide hammer that can expand to grip the inner race portion and pull the bearing.
SubSailor we are on the same page . 20 mins before you post this idea with the dremel , i was thinking the same thing LOL . i will make this work ,
You shouldn't have to cut all the way through the race. Only enough to weaken it. Bearing steel is hard, but brittle.
Be very careful not to cut too deep and into the case. Then the game's over.
You may be able to make a pie segment cut and be able to tap on the outer edge with a punch and hammer to shatter the race.
so right at 9am i got a call from the shop , they said bring it back , the mechanic wants to try one more time , so i droped it off , this is better anyway , if something goes wrong i get a new one , thanks for your time ,
i got the case home now , all is done , just put it on the bike , going to let the sealant set up over night , then fill it up with oil and antifreeze , then ride ride ride , PS best part shop did it all for FREE FREE they felt bad that i had to make all the trips , funny only 5 mins away , well thanks everyone
dremel :) glad he did it , thanks now everything inside is new - from the impeller to all the seals and all the o-rings , i got the parts on the hook up price and still was parts alone $120 so im glad they did the work for free that saved me $50 ,
Earlier this year I had a leaking water pump seal, so had to try and remove the bearing too, using a press. I ended up cracking the outer case as it bent from pressure applied. Really difficult to get the assembly into pieces without specialist tools specific to the job, I think.
So I ordered a new assembly, but didn't realise from my parts book the SP1 & SP2 had different coloured outer covers. No biggie, works just fine.
Getting the outer race using a dremmel would have been a possible but probably a very time consuming solution. Best to just get the assembly and be done with the lost time, I think... In any case, I kept the parts I'd bought so if the same problem occurs again, I could have a solution in case of non availability of parts in future...
i got lucky the shop hooked me up , i think keeping fresh antifreeze in it will help , and i here that blue ice is very bad for the seals , so only water-wetter from now on , on the track instead of just water ,
I replaced the bearing and oil/mechanical seal not to long ago on my SP1.The pump shaft pressed out no problem, but I removed the bearing with a very small puller rather than pressing it out on the inner race.
Discussion Starter #15
i think that would have been the best way , i replaced the bearing and oil/mechanical seal every o-ring +++ everything that i could put new i did ,
So sounds like you're all put back together, right? Ready to roll. Did you ride your RC51 on sunday or a different bike?
Good job, glad the shop made good for you. Who was it?
1 - 16 of 16 Posts
