I am putting a bike back together that was cosmetically destroyed and having a few issues…
#1 Indicators: I am not getting any response when I try and use the indicator on the cluster or to the signals. I know the left controls are working because the high beam light will register on the cluster…although no headlights are installed yet. I installed a new cluster along with an under tail and I am 99% sure the indicators are wired correctly. I do not have indicators on the front yet. If the lights are not wired correct should it still register on the cluster?
#2 Brake lights: When using the front brake the lights come on but only for the first ¼” of the throw…then they go off. Any thoughts? The guy I purchased this project from installed some shitty levers but not sure if that’s the issue?
Thanks!
I would start with installing a known good relay for the signals. The relay is in the trunk area near the rear taillight. (Normally)
There's a little switch under the brake master that the brake handle pushes to make the brake lights come on. It has two leads attached. I guess I would test those leads with a multi-meter to see if the switch is somehow loosing power or contact during the throw of the brake handle. Other than that, it's just about testing and inspecting the associated wiring.
Thanks for the quick reply! Is the signal relay the one the right or left? The other is for the ignition correct? Would a bad relay prevent the signal indicator from registering on the cluster?
Thanks again!
Good advice JD9. Pretty straight forward.
OP. Your answers begin in the service manual. Plus there is no way to know if any more specific wiring advice is correct since so many bikes have messed up wiring and routing, which you need to determine for your own bike. Use the proper SP1 or SP2 diagrams. And make sure you are correct by doing some basic testing.
I can't help specifically on the signals as my bike is much too apart for a check. So without any other input which is not really needed, wait to test signal lights and dash indicator until everything is hooked up first. The manual again has info to evaluate once you test.
The front brake light issue is quite easy to at least initially diagnose before coming for advice, which may be why it has been quiet. It's hard to give advice until basic assessments are done. As mentioned, look, identify, examine. Find the lever switch, examine it with the aftermarket levers and their usage, then test the switch if needed.
The service manual is the bible, start there, and let us know what doesn't work from it. Hope this helps and good luck.
