1 - 20 of 26 Posts
I have almost finished building my SP1 from a barn find bike.
The indicators didn't work and I asked the garage to sort them before carrying out MOT. Picked bike up, battery was dead but they said all was sorted with a brand new MOT.
Got the bike home and fitted a new battery, no indicators, same as before! :-(
Phoned garage and they just said "well they were working before" - so I have wasted a lot of money and six weeks of my time for nothing.
Anyhow, I need to get sorted, I have very limited time but had a play this bank holiday. Checked wiring which all seems intact. The indicators all light up when powered from the switch connector so points to a problem with the switch itself.
Apparently they had to get a specialist to diagnose and repair the switch, which is where the bulk of my money went, and he seems to have done ... nothing!!
I was looking a trying the switch from my SP2 but its different so I doubt would be a fair comparison.
If I flick the turn switch the relay clicks but nothing happens re lighting up or flashing etc. Headlights work, main beam and high beam, tail light works, front brake works - rear brake doesn't though. Checked all the earths.
Bit lost now - not sure what to do next?....
Okay, so the front ones should be lit up. they are running lights also.
Just to verify
- When you push the blinker(indicator) switch the dash does or does not blink?
If the dash light is blinking we know it is probably not the switch.
-Are the rear indicator lights always on? They should not be.
- Do you have any contact cleaner?
Front ones don't light up - I have no lights as running lights, I have running lights on the switch (each corner of the headlights), then main beam then high beam.
Dash doesn't blink when you hit the switch, but it does light up if I power the blue and orange lead out of the switch leading to the rear lights.
Rear Indicator lights are not on.
Will try spraying contact cleaner in the switch and see if that helps :)
Tried contact spray, nothing changed, apart from the passing switch worked for a split second then stopped again! :-(
If the switched worked for a second then that may be it. You could take it apart and really clean it. also check the contacts on the end of the switch harness. It should be under the left side of the front fairing.
Also are all the bulbs good for sure. You can also jump some of the wires in the plug to test them.
Yeah jumped all the wires and all bulbs are present and correct.
The bike is still stripped with just the tank and nose on so everything is nice and easy access - I want to get this sorted before I rebuild it.
Really miffed that I have paid good money, lost six weeks and still have to fix it myself! :-(
Judging by the MOT comment, I'm guessing you are in the UK or Northern Ireland. Not sure if the UK version has running lights.
My insight from playing with indicators is that unless the engine is running, you may not get the flash you expect on the lights themselves or the gauge, even with a new, completely full battery.
Just my pennies worth though.
Yeah - I'm near Portsmouth, UK.
Tried it with the engine running as well and still no joy - think i'll strip the switch myself and take a look inside.
The only thing I can't work out is if the switch is not working then why does the relay click? The relay doesn't click back until I turn the key off again. But if the relay clicks then in theory the lights should light up and stay lit up?
No expert but sounds like a 12v problem. If it engages the relay then it's got enough to around the system. Bad memories of my old 6v VW Beetle! Hahaha
Is it the flasher relay you hear clicking? if so is it only coming on and not clicking on an off?
Yeah its only clicking on (but no flashers light up) and then clicks off when I turn the ignition off via the key.
Have you tried substituting the relay? Brake light is a separate issue.
That was my next port of call - I will see if the one on my SP2 is the same and swap them over.
Reluctant to buy, one as a guess, as they aren't cheap at nearly £60 a pop for a genuine part.
For the flasher relay? The SP1 is part number 38301-KK9-952 and is only like $37.76 The SP2 relay is 38301-MBW-D21 and is only $28.47
A flat small flat rate box to the UK is only 33.95 still better than 60p and you may can find shipping for cheaper.
Discussion Starter #15
Yeah would have to include import tax and handling fees as well so would end up more than £60 I reckon :-(
Haven't got up to my SP2 yet (different town) but wondering if it will work at all if the part numbers are different?
May just order a cheap one off amazon designed to work with the LED blinkers at £10 its worth a punt :)
Discussion Starter #16
So - tonight's progress.....
I took the relay off my SP2 which is a 2 pin denso unit. Plugged it in and nothing changed, no lights.
Took the switch off - stripped it and checked all the connections, all nice and clean. Check continuity of the slider switch in every position, all good there.
I checked the connections on the three pin relay plug and got the following:
White & Green - Power supplied at 12V Constant.
Green - Earth is all good and confirmed continuity.
Grey - Solid connection to the handlebar switch, light illuminate if you power this directly (but don't flash of course).
So its pointing back to the relay.
Im guessing that the SP2 relay is non-compatible being a two pin relay on a three pin configuration.
the cheap relays for £10 say they are suitable for an SP1 but after the result of the SP2 relay I doubt it.
Im going to strip the relay next and have a look at that before I have to mug an old lady for a new one! :-(
Sounds like the relay if you can jump it at the relay and they come on.
Discussion Starter #18
Im not gonna be stripping the relay as its bloody sealed unit! lol
Looks like i'm off to rob an old lady ;-)
Discussion Starter #19
I tried bridging the white and green to the grey - which should have powered the lights, but nothing happened?
Cant figure out why that would be?
Discussion Starter #20
So this didn't work - which in theory it should have as I have 12V coming down the the white and green and the grey can be switched to either indicator via the switch.
I should have the indicators on constantly using this method but sadly not??......
1 - 20 of 26 Posts
