· Registered
Hey guys I'm sure this has been covered. There are no more fuel pumps on the market.
Can I fit a Cbr1 pump to this tank? Is there a pump that fits this bolt pattern?
Thanks a ton!
Ray
· Registered
Discussion Starter · #5 · (Edited)
How many miles did both of you have before the pumps went bad.
18k I think. I'm not getting current past the housing. Any advice?
I install the pump not go
I test the housing.. no current passing through.
I hook the pump to power it fires up..
I can't point the housing as the problem....
I was just looking for a drop-in solution but I cannot find the 16700-MCF-D61 part anywhere :(
Im kinda desperate here!
Thanks in advance!
· Registered
Mine failed at 27,000 miles but It probably had more to do with age (17 years) than miles. There is a diagnostic procedure in the shop manual you should follow before you replace the pump.
