1 - 14 of 14 Posts
hello......, i've got a jardine 2-1 exhaust.
Looking for a replacement exhaust can. Anyone willing to part with one?
Thank you.
whats the inlet size on a jardine can? maybe cross reference from a different maker
Ogiehooker........., THANKS for the numbers on the outlet, I wasn't quite sure what they were and hadn't got an opportunity to measure it on my bike. Good lookin' out!
Shrieves 41, I've got the entire 2-1 system, but my can has some rash. Really hoping to replace can only.
Wingnut...., holla at me regarding the can after you measure it. If it fits my set up lets talk!
yea any 60mm can should be able to be shimmed down. just make sure the tabs where the springs mount are in the same position
Should I be concerned about any gaps, or would such a small space be un-noticeable in regards to sound and performance?
any gaps less than .5mm should be filled with High temp silicon gasket maker. (the red stuff)
but really with the shims and springs etc. there should not be much if any leaks.
1 - 14 of 14 Posts
