Does anyone make a kit to to lift the rear end? I know on the gsxrs, you can get some longer dogbones. I want to come up 1 or 2 inches.
If you're referring to the HRC link, it won't work as the HRC link is designed to use a shock with an eyelet lower mount.Just add a shim / washer to the bottom of the shock mount, takes half an hour and is almost free, I went with 4mm.
I'm interested in the HRC style linkage, would this work with the standard rear shock?
Yeah thats the one. I was thinking hrc/mori/dankyle/this onIf you're referring to the HRC link, it won't work as the HRC link is designed to use a shock with an eyelet lower mount.
The Dan Kyle link uses the HRC link geometry, but uses the OEM clevis style lower shock mount.
It raises the rear by around 13mm and changes the rising rate ratio from progressive to linear.
It definitely quickens the turning response. Try it with a 190/55-17 rear tire.
You may be quite pleased.
Yeah I was aware that it was one or the other, I'm just wondering if the changes to the action of the shock would be worth it on the stock showa unit.Adding the DK link precludes the use of a shim.
Both the link and the shim raise the rear and quicken the steering.
Don't do both.
With the DK link in place, the bike does lean a bit on the side stand.
You can just be careful or order an extendable side stand.
hi, do you mybe know what is the difference in lenght between original and hyperpro kit in "mm" (between holes)sORRY FOR THE BLUR PICTURE.....IT WILL RAISE 20MM OF YOUR REAR
