1 - 20 of 24 Posts
· Premium Member
When I first bought my SP2 I did so blindly. I knew there were differences with fueling mainly with regard to different injectors, ECU and larger throttle bodies but didn't realise there were so many other small changes.
I think it might be a good idea to list all the differences we know collectively, so people can use this for reference in future. Feel free to add to details below or amend with further info, etc.
Anyways, assuming people think it's a good idea, I'll start:
(1). Different swing arm between models. SP1's is extruded aluminium, SP2's is hydro formed aluminium, slightly longer and lighter.
(2). SP1's injectors are 2 hole, SP2's are 12 hole for finer atomisation of fuel.
· Premium Member
Larger Throttle bodies on the SP2
SP2 Frame has bungs for Side mount steering Damper
SP2 has 2 cooling fans operated by ECU/Relay, whereas the SP1 has 1 fan operated by a Thermal switch mounted on the Radiator
Different ECU's, due to TBs
Different wiring harnesses. Sp1 mounts ECU center of the rear cowl, Sp2 mounts ECU next to battery
Different sized velocity stacks.
Different front fairing stays
· Premium Member
Pretty sure the SP1 swingarm isn't cast iron. It is just extruded aluminum and not hydro formed like the SP2. It is heavier and shorter though. The pivot bolt is also smaller on the SP2, which requires a sleeve not available from Honda unless you buy the cases for an SP2.
Here is a post I did on another forum:
To tell the SP1 (00-01) from an SP2 (02-06) there are many different things besides paint to check.
Here is a breakdown on the paint schemes:
-00-02 are the same paint
The rest are all different paint schemes:
-03 red/silver, black wings are a tad different than the rest of the silver/red bikes, No "Honda" along the bottom, smaller flat black area on the front vs. big number plate on the 00-02, black tail with silver number plate
-04 Nickey edition, black wings match the 00-02, but it has the signature on the tank, came with stickers (some didn't get put on at the dealer), bare frame, silver tail, white numberplates front and rear, says "honda" along the bottom of the side fairings, but it is a little higher up to allow for the stickers
-05 black/grey, doesn't say "racing" under the RVT on the side, little Honda wing logo on the tank is black
-06 black/grey same as 05, but little Honda wing logo on the tank is silver
Differences between SP1 and SP2:
-RADIATORS SP2 radiators have three mount locations, and two fans as apposed to one, SP2 also used the ECU to turn the fans on, SP1 used a thermo sensor in one of the radiators
-OIL COOLER SP2 oil cooler is vertical on the left side, SP1 is horizontal in the center. This means the center "V-cowl" is different.
-REAR FENDERS The SP2 fender is easy to spot as it places the ECU in a vertical box on the right hand side that sticks out below the tail at the front. SP1 fenders have the ECU laying flat.
-SUBFRAMES SP1 has two fairly stright pieces of square alumiunum tubing and some extruded pieces that go up to the top mount, SP2 has some bent square tubing that goes under the seat and to the top mount, then smaller sections going to the rear.
-SWINGARMS SP1 is ugly, SP2 is awesome. Oddly, the '01 was the only year without bungs welded on for stand bobbins
-FRAMES SP1 has a smaller cast front frame spar, SP2 has a stamped larger one, SP2 has gussets inside the frame by bottom of the steering stem, SP2 has holes for the extra radiator mount, and SP2 has a bung welded on the left hand side for a steering damper, SP2 also has a larger diameter steering stem
-WHEELS SP2 has five spokes, SP1 has six
BRAKE ROTORS SP1 front rotors were only 4.5mm thick, SP2 were 5mm thick. Both were 320mm
-FORKS SP2 have a longer top out spring, SP1 have silver preload adjusters on the top, SP2 have larger black preload adjusters that look just like cbr adjusters. The caliper bracket mounting bosses on the SP2 forks are one long tab with two holes, SP1 forks have two separate tabs for each bolt. '05 and '06 also have a lighter gold anodizing finish on them, others have a dark bronze color.
-REAR SHOCK SP1 shocks have the reservoir going up and back like cbr's, SP2 have it going side to side
-ENGINE SP1 have round exhaust ports, SP2 have "D" shaped ports, The right hand side cover (the larger one behind the round clutch cover) is silver on SP1 models and painted gold on SP2 models to match the clutch cover and valve covers. This is the case for US spec, others may be different. The SP2 engine has a sleeve for a smaller swingarm pivot bolt. The sleeve isn't sold through Honda without ordering cases for an SP2.
-EXHAUST HEADERS Different port shapes to match the heads, and different routing of the pipes. SP1 and SP2 exhausts are NOT interchangeable unless they are full systems, but some of those might hit the swingarm if it is incorrect for whatever year the exhaust was designed for, slip ons are not interchangeable unless you swap headers or can cut and weld them. This also means the stock canisters are different and will interchange.
-FRONT FAIRING STAY SP1 had a black steel unit, SP2 is bare aluminum
-THROTTLE BODIES are larger on the SP2. Which means the airboxes and velocity stacks are different.
-FUEL INJECTORS SP2 are 12 hole, SP1 are 2 hole
-ECU's are different due to the injectors and cooling system differences
-WIRING HARNESSES are different for the same reasons as the ECU
-TRIPLE CLAMPS are different due to the steering stem differences, SP2's have a larger stem
Obviously paint and swingarm are a dead giveaway, but those can be swapped. Best way to tell without taking off the fairings is to look at the steering stem nut (much larger for the SP2), the engine cover on the right side behind the clutch cover, or the oil cooler location as these are things that wouldn't/couldn't be swapped.
· Premium Member
Discussion Starter · #4 ·
Thanks b.miller123 & gts455 for taking the time.
Sorry, mine is an assumption, sounds like the SP1 does has an aluminium swing arm (A magnet would answer that for certain) - I'll edit above.
Perhaps further down in the thread someone can tidy up & edit the list once we've got all the differences listed. Are there any more differences anybody knows of?
The rear brake carrier is different since they have to fit different swing arms - this means that underslung kits are model specific.
Not sure, but I thought the fork diameters are slightly different (SP2 thicker), but I could be wrong. Has anybody successfully fitted SP2 forks on SP1 clamps?
Also not sure, but I think the fuel tank leaks from cracking only occur in SP1's (& presumably Honda fixed the problem for SP2's) is this true?
· Premium Member
Discussion Starter · #5 ·
Clutch cover & gearbox (right side) cover are all same colour on SP2, only the magnesium portion is coated on the Sp1 (I know because when I ordered a new one due to leaking water pump seal, I mistakenly asked for an SP1 model's! :D)
· Premium Member
B.miller got all the big ones. Forks are interchangeable. No size difference.
The SP1 tanks were notorious for leaks (Mine did), it is less common on the SP2's especially the later ones.
· Premium Member
True, but don't forget about the caliper mounts as they don't interchange properly.
& not that it matters in the context of what I just posted, but as I recall the piston sizes of the SP2 calipers were different than those of the SP1
Yep, I forgot about that part. The SP1 mounts have material that interferes with the fork bottom of the SP2. I'm not sure about the other way around though. The lugs on the SP1 forks may be too big to fit into the reliefs on the SP2 brackets.
I think you are correct on the calipers. I think the masters were also different sizes.
I've just never had the SP1 calipers and stuff to confirm those.
· Premium Member
yep, as long as you have the caliper brackets off the SP2, you are good to go on the forks. Forgot about that, but when you mentioned it thats what i had to do to get them to fit.:)
· Registered
What about engine mounting? Are the bolt and mounting locations the same between the SP1 and SP2 frame and engine? Also, what about the clutch or drive sprocket? I'm fixing to do a engine swap, putting a SP1 bottom end into the SP2 top end and frame.
· Premium Member
Make sure you have the swing arm sleeve then, assuming you are mounting an SP2 swing arm.
· Registered
^ I really don't think so. The contours of the swingarm are different. I'm certain that SP1 and SP2 huggers don't interchange, that's my reasoning for why chain guard probably wouldn't either.
· Registered
Anyone know if the SP1 wheels are a direct fit with an SP2 model? I know the wheels changed from six spokes to five spokes and I could swear everyone wanted to take SP2 wheels and fit them on the SP1 but is it a straight swap from one model to the other?
· Premium Member
Discussion Starter · #18 ·
Would be a direct swap. :)
· Registered
Straight swap. I just put these Oz wheels onto my SP1 and they came off an SP2.
1 - 20 of 24 Posts
