Hi SubSailor:Just curious, but what happened to your existing one?
BTW I had to replace the rear rotor carrier last year due to a hairline crack, and noticed the replacement was redesigned.
I've never had a problem with my cush drive, only a hairline crack on the rear rotor carrier.
Possibly due to the previous owner laying it down on the right side.
I found it while cleaning and inspecting parts last year during the refurb.
The U.S. distributor for Marchesini is TAW Vehicle Concepts.
The contact there is Jolene.
This is where I ordered the replacement rotor carrier and also where I obtain replacement cush dampers.
Because the rotor carrier was a safety related issue, Jolene put a rush on the order, so it only took 2 or 3 days.
http://www.tawvehicle.com/
Did you also order the cush dampers to go with the cush drive?Gave it a shot, it will be 4 to 6 weeks or longer due to some hollidays.
Very difficult to deal with this situation.
Hey thanks very much appreciated!
I will try alternate means for now.
Regards,
pv2
I have the rubber pieces - 5 of them - I think those are the dampers yes?Did you also order the cush dampers to go with the cush drive?
Or do you already have them?
Correct.I have the rubber pieces - 5 of them - I think those are the dampers yes?
pv2
Glad I saved myself a few bucks!!!!Correct.
And FYI, they're $12 each.
Gold, it matches the brakes, the Ohlins Forks, Shocks.BTW What color did you get the in?
