Hi
i am installing the marchesini 10 spoke front wheel and I need a couple of photos of the set up of each side of the axle.just to make sure I've got it right. I have the Kyle red spacer and the two marchesini captive spacers one longer than the other one.
Is there anything else I need and which way do the captive spacers go. Long captive spacers left or right when sat on bike.
Thanks guys.
Thanks Wibbly.
So the longer marchesini spacer goes against the red Kyle spacer.
The shorter spacer to the left and that's it nothing else needed. Forgot to say it's for the fg322 ohlins forks.
Thanks Ian.
Should be simple to tell. The Kyle spacer will have an inside diameter that will only fit one side of the axle, So you can't really screw it up. if you get it backwards it'll be painfully obvious when you try to mount the calipers
Hi.
No I'm fitting all this at the weekend. and I bought the wheels second hand no instructions so just wanted some info before I start.
Thanks guys.
