hello , i have a 00 sp1 with 13k miles , pc3 , slip ons and high flow filter . i was riding around this morning and all the sudden the bike started to misfire and lost almost all power , i was barley able to limp home , did not get over 165 degrees . the exhaust pipes are smoking thick white smoke and it smells like raw fuel. i tore it down pulled plugs checked compression witch is at 175 psi and holds. plugs look ok , front one was pretty white but sparks fine. if i let the bike sit and cool i can start it up and runs fine with no smoke until it warms up then its starts to bellow white smoke. any idea or pointers on what i should took for ? i was thinking head gasket but that doesn't explain the raw fuel smell and i used a head-gasket tester and the fluid did not change color so im kinda lost any help would be great
thanks you
mike
