Looks just like a Hotbodies.
It's FG and has 4 wires. Red, Black, Green and white.
Any ideas of the manufacturer and what wires are what?
To hazard a guess:
Green for ground
Red for brake
Black for running
White for license plate (if it has one)
If you have your rear cowl off and access to battery, just try touching wires across the the positive and negative battery posts to determine function.
That's what I did to map my wires out.
The LEDs don't draw much current when forward biased.
No plate light. Has turn signals though, so maybe whites are for those...
Do you really think green is ground and not black?
I guess I should have looked at it better before I cut up the stock one. lol
i just went through that crap with my undertail. junk, junk, all junk...
my neightbor is into electronics and bikes. so, he did the work for me and i am very thanksful for that. he did just what sub said for the wires on the tail side. on the bike side he put the ket "on" and used a meter to determine what wires did what.
At the worst, you'll reverse bias the LED and it won't light.
Are you sure you have 4 and not maybe 5?
You usually find a ground, brake, tail light, and two turns.
Discussion Starter · #6 · (Edited)
4 wires on each side.
black, red, green and white.
I found:
black = ground
green = directional
red & white = running light or brake. They both work either way.
here's a pic. Scuse the mess. lol.
Discussion Starter · #8 ·
If you lost speedo, tail, and illumination, it's Fuse E (10A) in the fuse box behind the left side cowl near the coolant overflow bottle.
Got it. :D I edited my post after searching.
It's pretty much done. Just have to button a few things up. I might do a little more trimming too. The cowl sits a hair low with it all together. I notice a little lip when I put the solo cover on.
Going to mount the plate and plate light tomorrow and wire up the flush mounts in the front. Hopefully should be able to ride by the afternoon. :)
