I'm going to change my plugs out this weekend, Just wondering which plugs would be the best to put in there! I have sato banzai's on there now and will have a PCIII with a dan kyle map installed this weekend too!
The black knob on the left side is the choke.If idle speed is lower than 1300 rpm when warm how do I adjust? can I? What is the knob on the left side fairing, when you pull it the idle goes a tad higher.
I agreed to the swap last night thanks to information from you.Quote:
Look on the right side at about the same position and you'll find a gray knob behind the cowl edge. That's your idle adjuster.
You may need to pop the quick release fastener near it to gain access.
