1 - 20 of 35 Posts
Alright guys, new here. Got the RC51 home today. It had NO front signals at all. It had an undertail LED kit installed already. Installed the front flush signals I got from RC-Devil and got them working. Right now everything works exactly as it should. Switch left all blinks left, switch right all blinks right, push center and all are dim steady for running lights. Only issue is the instrument cluster light never goes out or changes, just stays lit amber. Once again, all of the switch activations work great. Any ides of where to start?
Hmm, try pulling the flasher relay, just disconnect the wiring clip and see if it goes out, with the LED lights thee might be an issue with the original relay.
Possible a feed is coming back from one of the daytime running lights front LEDs you could eliminate this (depending how you connected them) Disconnect them one at a time to see if that is the source... Electrics difficult to diagnose remote.
But if this does not work disconnect eveything front and rear then connect back one bit at a time, to see which component is giving the volts to the cluster.
Good luck
Thank you sir. Did exactly what you suggested up front, but have not in the rear. Where is the flasher relay located? Seems like if it was the flasher it would not flash at all...but that is coming from 1967 VW beetle knowledge!
Flasher relay is located in the tail of the bike. Your blinkers might also be blinking a bit faster than normal due to not having the LED flasher relay. New relay is $30ish.
Wadmaemgee, yup its a small black cube rubber mounted on outside of the frame through the tail cover, about half way along the tail aperture, next to the rectifier on the LH side. The one on the inside of the rail is the tip sensor, disconnectthat and the bike probably wont run.
i would send piccy but my RC is in the shop right now for suspension work, but I would advise trying disconnecting the rear running lights/side lights too, as a steady instrument light may indicate a permanent feed possibly caused by having a running light crossed somehow with one of your indicator feeds.
The reason I suggest the relay, as weyrauch, is putting turn signals from filament bulbs to LEDS can have funny effects due to incorrect loading on the OEM relay. elsewhere on here there is a link for a replacement solid state one, which I fitted to mine about three weeks ago to cure the rapid blink rate, $24 shipped. (Ledcustom).
Apologies for basics, but remote diags are difficult. Did this constant light occur after your fixing the previuos owners work or was it present on purchase whith the front turn signals missing? If the former I would suspect the undertail installation wiring may have a turn signal/ running light possibly earth return wrong. Only way to know is to disconnect there to see if it goes. A proper aftermarket modification ( tail) should have 'connectors' to allow body work removal, so it should be easy to disconnect for testing.
Elsewhere in forum is a pdf manual, within is a cct diagram, I have a hard copy and happy to fax/ scan the relevant page to you, then you could check the wires are as they should be.
If so I can do tonight, just off to work. Good Luck - john.
Depending if you have a SP1 or SP2 the blinker relay location varies, but on my SP1 it's located just in front of the OEM rear brake lights. Cycle Gear sells OEM replacement Relays that work great with either bulbs or LED's. I spent about $20.
As far as your blinker indicator staying lit, I have nothing. Sorry. Obviously it's getting power when it shouldn't...?...
Correct, but both SP1 and SP2 should have the relays located in the tail correct? Unless the previous owner relocated it. For the SP1, flasher relay should be located at the rear of the tail, in between the two brake light bulbs. For the SP2, should be mounted on the left side of the tail, on the outside of the subframe. Then again I could be completely wrong. 19-9, 19-23 in the service manual shows a rough picture of the two different locations.
20-1, 20-2 of the service manual also shows all the wiring diagrams.
Hope you get it sorted out.
Weyrauch is correct the sp1 sp2 differ, the 1's is in the rear of the tail, middle one of three by the rear lights, my own (apologies) is Sp2 which is mounted on outside of rear frame rail right next to the rectifier......diagrams on 1-35, 1-36 have clearer drawings, not pictures, for bits locations, Weyrauch do you know the pdf link for the manual ?
Id bet my socks on being incorrect rear unit wiring, especially if it has the combined flash, and tail light as some tail tidies have ........ Does it have connectors or has it been soldered up? ;)
The fecking wiring is mashed.....sort it our and the craziness stops.:eek:;)
LOL thats the direct terminology for it! :D.
Get hold of the workshop diag, disconnect all the rear and start again. And no matter what blame the PO - previous owner !;)
Thanks guys, more to follow but I am putting new miles on the old girl now!!!
Sorry for the delayed reply...
Enjoy!!!
Thanks weyrauch... This site is the best!
Mind you thats hell of a 'user handle' to rember to spell right! Ooops old cb radio terminology ....... Years are a showin'..........
Pronounced (Y-Rock)...so Rock is what most people call me.
Glad I could help.
It's not relay. The rear signals should not be wired as running lights, as per the service manual. To do so will result in a dash bulb error.
This has been mentioned before. Use search if you wish.
Discussion Starter #16
Alright guys, update. Went through the wiring best I could...so far. Removed one bulb at a time from the system, not response other than the rest still working. Removed the rear flasher and the flashing system stopped, along with the orange light in the cluster. No signal response from the cluster and not signal at the 4 corners. Plugged it back up, all blinkers work as they should, and not a fast flash. Flashing at a rate I would consider normal. Still have the illuminated orange in the cluster. I would say it flashes every 1 second...second on, second off. Is it worth just trying to replace the flasher relay first, then try again? I can live with it as it is, just a pain in the ass and not correct... Help...
So with no blinkers on, the blinker indicator stays illuminated correct? You must have a running light wired incorrectly somewhere (so it seems). Do the rear blinkers stay illuminated like the front (the shouldn't)?
You said you removed the "rear flasher"...and the indicator went out, are you saying you removed the relay?
I'm understanding that even with your turn signal not activated, switch in the center position, your turn indicator on the dash blinks off and on? Just like a turn signal does?
I doubt it's your relay, much more likely to be some jacked up wiring.
Many hondas use the same signal relay, do you have a buddy you can try swapping the turn signal relay? Or flasher as you called it-same thing.
1 - 20 of 35 Posts
