I have been searching the forums, but I am not sure what I am searching for. I have an '01. The only mods done to it are a PCII, K&N, an upgraded fan, and a switch to reverse the fan's polarity. I have run the bike with all of the stuff done, several times. It only has around 5k on it. The problem is one time, I started the bike, loaded it on a trailer, and killed it. I tried to start it again and got no power at all. When I turned the key on, there was nothing, no lights fuel pump or anything. I am wondering if it may be a relay or the ignition switch and figured I would see if anyone has had this problem before. Thanks.
Discussion Starter · #2 ·
Oh, and I don't know if it makes a difference, but the clutch doesn't seem to have any resistance anymore, like it needs to be bled. I will be working on this in the meantime, but did not know if this would impact the problem or not.
Oh, and the battery is not dead because I went and got a new charger with a 200 amp option and still get no power to anything.
you might want to check all the fuses... and also the main fuse the the tail end of the bike... hope it helps...:)
Discussion Starter · #5 ·
Ok, I feel like a retard, the plug for the ignition came loose somehow. Ok to delete thread. Thanks for the input slinkykatyus.
