I was wondering if anyone else has experienced this problem: the rear cylinder on my CA model 2001 RC51 doesn't fire. We; the mystified mechanic and I have replaced the spark plug checked the fuel pressure swapped out the throttle bodies with a 49 state model to no avail. It will fire/ignite if either is sprayed into the rear throttle body. Any help would be appreciated.
Have you checked to see if you have voltage reaching the injectors? If so, have you tested the injectors? Likely a broken wire in the harness or loose connection.
1) Are you getting any FI errors?
2) When you pull the plug, is it wet or dry?
If you spray ether into the cylinder and it fires, then you're getting a spark.
If your plug is dry, then you're not getting fuel sprayed into the cylinder, but I'd expect an FI fault code 12 (injector 1-1) if the low throttle opening injector coil or wiring was shorted or open.
Use the service manual to verify both injectors coils for the non-firing cylinder (cylinder 1).
The #1 cylinder exhaust cam has the cam pulse generator sensor, but that too would cause an FI error, and the entire engine would fail to start.
