So I hooked it all up. Red ignition plug, fuel injector plugs, ground. Turn the key and my injectors are 3 times as loud as the were. What's going on there?
unusual... is the airbox/ tank, and bodywork all re-installed? there should be no difference in the injector sound, as long as everything is properly reassembled.
Yeah reinstalled everything. No pinched wires. I pulled the tank bolts and lifted that up and still loud. Its like it's not pumping gas through. If I turn the key on and off a few times it sounds normal. But the first and second turn is almost always louder. Start the bike and it's fine. Rode it with no problems. No backfiring or popping. Smooth throttle. Pulled in the garage turned it off and turned the key and it was loud the first turn but not the second. Have the sato low mount rogue map installed on the pc3
