Hi.
Does any body no if the radial brackets that fit the ohlins fg324 forks.
Fit the fg322 forks.
I've got someone saying they are the same.
And that ohlins says that they are?
Just need to be sure.
Thanks .
I used the brackets from the cbr1000rr forks on my 322s.
If the 324 is the CBR 1000rr fork then you're good to go.
those are the oem ohlins radial brackets from a 1000rr. also has a 1000rr fender mounted.
notice the 5mm spacers for the calipers, the 1krr used 310mm rotors, so for 320s you need spacers.
