1 - 2 of 2 Posts
Hi does anyone know the torque settings for the oil cooler pipes to the engine and to the:) oil cooler as can't find them anywhere,
Thanks
If not noted in the specific service steps, refer to the section on torque values beginning on 1-11 in the service manual.
Which states:
8mm flanged bolt and nut, Engine: 17 ft/lbs (204 in/lbs).
8mm flanged bolt and nut, Frame: 20 ft/lbs (240 in/lbs).
6mm flanged bolt (8mm head, small flange): 7 ft/lbs (84 in/lbs).
6mm flanged bolt (8mm head, large flange): 9 ft/lbs (108 in/lbs).
6mm flanged bolt (10mm head and nut): 9 ft/lbs (108 in/lbs).
1 - 2 of 2 Posts
