Hey Folks, I know I'm running an obsolete discontinued exhaust, but it's what's on there for now. There is ALSO a PCIII in the tail and I have a concern that it may be set improperly based on some other issues in the bike I had to correct from the PO.
Does anyone know which MAP would be similar to the one I need? I'm guessing it has to do with Flow and backpressure of the exhaust but I'm at a loss.
The one it's running right now might even be correct, I just want to be sure.
It's not dialed in elsewhere for me to be concerned with a custom map, so that's out for the moment.
J
Go to rc51.org and head to the MODs tab and see the PCIII map page. Start with the map that is similar to the mount that you have and that will be a decent starting place. You will also be able to compare values between the map currently on your bike and the the one you download. NOTE if you do not have a solid understanding about the basics of tuning DO NOT mess with the values in the tables!
I Wouldn't call it solid at this point. I can hold my own with the Supras but I don't plan on jumping into anything without being super careful here. I also don't know what's going on with the air cleaner, or if there's been a flapper mod etc. Suppose I better just crack it open and have a look see in case there's a K&N reusable etc. I hate opening stuff up if I don't have the stuff I need to swap it out since I'm there..
