can you remove the front piston and connecting rod without completely dissembling the engine? I was thinking of leaving the engine to the frame.
In order to get to the pistons and con rods the engine must first be removed from the frame and disassembled. I can’t imagine how it could possibly be done any other way.
Don’t know if you can do this on the RC but I have seen a few motors where you could get to the con rods after oil pan removed. After heads removed the rod & piston goes out the top. Probably easier to r&r the motor though and at that point split the cases and do it right. Interesting question though.
