1 - 16 of 16 Posts
Alrighty have some kind of issue here. Been waiting on my plates and reg for the bike and havent got to ride. so put on some swingarm spools the other day to put her up on the new reaer syand I just bought and it fell over in my shed of course hit the left mirror and sheared vit off so had to order one of those. Now got
to ride her when I first bought it and it ran great so no worries there. So after I dropped it picked it up and she wouldnt start. So pretty much killed the battery so had it tested and it was bad so put a new battery in it. She still wont start cranks over fine fuel pump comes on pulled the rear cover off and nothing seems to be wrong. Kinda lost at this point this sucks cause I just wanna go for a ride. Any help or ideas are greatly appreciated.
Thanks in advance,
Todd
Tipover switch maybe? That's just a guess so don't take it as fact, I'm also new to the RC so don't know where it would be located, but something to research?
Already tried that found the relay but have yet to find the actual sensor which should be there but no dice. Have the honda service manual but havent found it yet.
That is good to know thank you. Gonna tear into it some more today and check plugs and such. Any advice is good advice right now.
Alrighty need to know if anyone has ever had the tip over sensor go bad on them and what happens when it does. everything else seems to be good. That friggin sensor seems to make the most sense to me its right where the bike fell over. It doesnt look damaged at all but Im ready to go to honda at this point if nothing else. Its had to have happened to somebody out there. PLEASEfor the love of God HELP!! As you can tell this is truly frustrating lol.
If your fuel pump is priming when you turn the key then the bank angle sensor is operating correctly. That relay is in series with the fuel pump feed and the pump would not run unless the sensor was picking up that relay.
Well that's good and bad cause its working which is godd but bad cause that means its something else.
If you have the service manual, work your way through the troubleshooting procedures. There are alot of electrical components along the left side of the bike, maybe a connection came loose during the tipover? If it was running fine before then I would assume something got knocked loose or damaged when it fell. Look for possible loose or broken wires/connectors.
Have you pulled a spark plug and checked that you are getting spark? At least then you would know if it is electrical or fuel problem. Has to be one or the other.
Yep it ran just fine before I dropped it. Already checked all fuses and general connections. The only thing that broke that sticks out to me is the mirror. Heck I rode it to the gas station to topp it off with fuel before all this happened.
Check the connections on the coil on left side . Mine died the first 2 times I rode it.checked all relays and such, turned out there was a10 mm socket on top of coil and when I leaned left it died.flawless ever since
You may want to check the Bank Angle Sensor and Relays. As Wibbly said if the pump primes it is a problem elsewhere but mine worked randomly and would occasionally not allow restart. Suggest doing a search on "Bank Angle Sensor" and confirm it is not improperly located or perhaps came dislocated with the tip over. If you are sure you are getting "fuel pump prime" when key is turned problem is probably elsewhere.
Check to make sure kick stand isn't somehow bent or the sensor isn't being tripped (into thinking the kickstand is still down). Work it up and down a few times and see if it does anything. ;-)
Edit: I know it shouldn't crank if that was the case, but I've seen some wierd gremlins show themselves on older bikes after light falls.
A 10mm socket?! Wow! That’s a crazy story.
Discussion Starter #16
Well Ill know soon enough took her to the Honda shop today so Ill keep ya all posted as to what they say
1 - 16 of 16 Posts
