1 - 1 of 1 Posts
hey guys. while i was riding i pulled over at a convenience store. i shut my bike down only by the key and when i went to start it it would crank but for some reason i lost my fuel pump, headlights, high beams, horn, and directionals. i noticed that i dont hear the bas clicking or my fuel pump come on. with this many things not working i was leaning toward a faulty ground but all wiring seems ok when i visually inspected it and my meter shows continuity on every ground. im lucky enough to have a spare cdi and ecu tried swapping them but that wasnt it either. none of the fuses are blown either. i checked all connectors for corrosion and even applied electronic grease to all of them. the only connector that was corroded was the relay next to the left radiator which was actually pretty bad, what is it for? i cleaned of the terminals but it didnt help either. does anyone have any ideas on what my problem could be? thanks. itd be awesome if someone knew what steps to take to troubleshoot this issue before i waste money dropping it off to honda. i also tried eliminating my pcIII but that didnt help either. (that doesnt come on either)
1 - 1 of 1 Posts
