I am looking for a Power Commander III USB. I recently put exhausts on my 2003 RC51 and don't want to smoke my motor.
Reading some posts on here it seems like you can use different PCs across the SP1s and SP2s as long as you have the correct map, so maybe I don't need a PC III specifically. Any help is greatly appreciated.
Thanks
I believe the SP1 and SP2 are different. The SP1 take a 105-411 and the SP2 takes a 114-411.
They have different part numbers but there is no physical difference between the two. Only difference is just the preloaded map from Dyno Jet and the number on the back.
Sent from Motorcycle.com App
they are they same, you just have to load the proper map
hardware wise same thing
Ah, let me rat hole that bit of knowledge in my data banks.......m'kay.:cool:
I see different part numbers, I usually go with what is recommended.;)
Yes, model doesn't matter as long as you are running the right map.
Lucky for you I will have my PCIII up for sale in about a week or so, maybe sooner. It has a custom map made for Jardine slip ons, for SP2.
PM me if you're interested
Very nice. Thanks!
