I have the older version of the software. Problem is that the map they have for my setup isn't compatible with the older software, however, it is compatible with the PCUSBIII software.
You should be able to use it. I am using the Sato Low map from Dan Kyle and it works just fine for bike (and I'm not running Sato's).
I thought I saw somewhere you can covert the maps.
Go here for some the more popular and better maps.
http://rc51.org/PC3maps.htm
I have never had good luck with pulling maps and running them off of the Dnojet website. Where did you get the map? Worse case, you print off the map you want and change the cells into your PCIIIr manually. Would take maybe 5 minutes to do.
It seems that's what I'm gonna have to do. Cell by cell fix a zero map for the PCIIIr to the map for the PCIIIUSB
