1 - 14 of 14 Posts
Don't bother. Those aren't real projectors. Head on over to the hid planet forum and look into what is recommended for motorcycles.
If you do a search on speedzilla you will find two guys that have recently done the retrofit. One used Infiniti fx projectors, and one used morimoto's. "the retrofit source" is where more people buy their stuff from, or eBay. The morimoto's are the ones that are easily installed because they can fit into the existing bulb socket with minimal modifications compared to other options.
Putting Hid's into a headlight that never had them, is really only done right with projectors. (sorry, but the kits are complete crap and will never compare to real hids in projector housings designed for hids). This means custom work, and making square pegs fit round holes. If you aren't comfortable doing this kind of work, there are places that will do it for you. You can count on a quality dual retrofit to cost you at least $300 in parts. For someone else to do it can add a few hundred more.
yea i had a feeling they were crap, i appreciate the feedback. Im pretty sure i can tackle the project, just need to dive into it.
+1 on what b.miller says. I'm assuming he's referring to me off speedzilla because I did my retrofit recently with the morimoto projector. I had my own obstacles to overcome with fitting the morimoto's in the housing. The biggest problem (literally & figuratively) was the size of my shroud. I got the bullet shroud and it was huge! I made it work but ended up having to ditch the oem reflector that I should have been able to use. I did have to make my own brackets from some scrap aluminum I had sitting around. Not impossible but definitely some trial and error on my part. HID planet was a very helpful resource - I'd start there doing the research.
Cool, I've done research on it before, the only part I'm not sure of s making a bracket for whatever I use, but I have a machinist friend so I'm pretty sure I can get it done. If u have some ideas of what I should do opinions are accepted. Thx again
Best advice I can give is to be 100% sure the projector beam is level and flat before you put the glass back on the housing unit. You'll have to test fit things a couple of times before it's right. I didn't think about double-checking the projector level before putting it back together(doh!) and now mine is off a few degrees. It's not a huge issue but it annoys the piss outta me everytime I start the bike since the morimoto lense has a very sharp cutoff. This goes along with fabricating your brackets. It really was just measure, cut a rough shape, test fit, trim, test fit, trim some more and so on. A dremel tool will be your best friend. My custom brackets definitely weren't anything fancy, I rattle canned them black so you wouldn't be able to see them anyway.
Also, when I made my brackets I reused the black rectangular screw adjuster pieces (you'll see what I mean when you take the housing apart). By reusing them and the screws already in the back of the housing you'll maintain the ability to adjust the light beam l/r and up/down just like oem.
Check theretrofitsource.com and get the dimensions of the Bullet shroud. Then be sure whichever one you end up using (assuming you use a shroud) isn't as tall as it.
thx for all the info
I'm going to hijack for a moment if you don't mind. I'm wanting to do this too, but is there a way to run both lights at the same time, and is there a way to do a high/low in each light?
This guy did a dual setup on his: http://www.speedzilla.com/forums/honda-rc51/66845-bi-xenon-projector-hids-my-rc.html
I had enough issues fitting the wire harness and ballast for one projector on mine, I am curious where he found room for two ballasts? Technically there is no high/low beam as it's always the same light output intensity on a bi-xenon projector. The high beam switch simply activates a solenoid that retracts a flap and changes the light pattern.
One of the guys that did both headlights used one of the slim ballasts from ??? and slipped them under the headlight housing. There is a tiny bit of room between the headlight and that black plastic piece that goes under the nose.
Well, i'm unsure on which kit to get. I've seen some say the FX-R, someone said a GTR, and then there is the motorcycle kit. I'm looking at getting them from theretrofitsource.com. I want the shroud to fit without any modification.
I can only comment on the single projector Bi-xenon motorcycle kit from theretrofitsource.com. This one came with a morimoto projector, a fairly large 35w ballast (same footprint but almost 2.5x as tall as a DDMTuning slim 35w ballast), a shroud of your choice and wire harness. It was a bit of a challenge to modify the brackets inside the housing to accept the mori projector but I was eventually able to make it work with enough fiddling. Reference my previous posts for my experience with the shroud. You will need to be handy with a dremel tool to make everything work.
The nice thing about the motorcycle kits from the retrofitsource is that they are complete packages. The wire harness is pretty big but is solidly made and has relays for two ballasts if you so desire. Based on that speedzilla thread and the looks of the FX-R projector, it might be slightly easier to make work but I'm not sure. Doing a full projector setup is definitely a custom job so take your time and try to plan everything out.
Man this adds up quick!
Just ordered 2 bike kits, with the 5k bulbs, and Orbit shrouds. Then i went to Dragon Plate and ordered 2 sheets of carbon fiber to replace the reflectors. Damn i can't wait!
1 - 14 of 14 Posts
