I am about to buy a Sp2 wire harness, I know it works on the SP1, I am just curious in why there is only 3 relays and not 4 like the SP1? What is the 4th missing relay on the SP2? Unless I have the models swapped, just curious.
I think you got it backwards. It should be, why are their four relays on the SP2 harness, and only three on the SP1.
The reason is, the SP2 uses a fan control relay while the SP1 uses a fan control switch screwed into the left radiator.
Exactly......and the harness includes some extra cables for that circuit as well that SP1's doesn't.
Ok, so to make it clear. Since the current wire harness has 4 relays on it and I have an SP1, it is safe to say tht it was changed out. And by buying one with only three relays I will have no problems. going to order it from Ben tomarrow.
There is an easier way...
Look at ECM's black connector in A16 pin. Is there a Green/Blue stripe wire? If there is one, then your harness is from an SP2. That one triggers the fans relay.
