All the swingarms will fit onto the bike, it's a question of how much modification and customer parts you want to make/buy. Perhaps the easiest iteration would be the SP1 swap. However, I am not sure why you'd do this because it's shorter and IMHO not as good looking (smooth and "aerodynamic") as the SP2 version. Good luck with your choice and ride safe.
The SP2 swingarm is 16mm longer than the SP1.
The SP2 swingarm also uses different diameter spacer where the pivot bolt passes through the engine case.
The Swingarm pivot bolt, frame inserts/nuts and engine spacers are different.
