1 - 18 of 18 Posts
anyone put 180/55,s on the rear? any opinions about this or does everyone stick with the 190?
A lot of track guys run 180's cause they're cheaper and more common.
Typically a 180 fits on a 5-1/2 inch rim. Our rims are 6 inch. But then again, I've seen manufacturer rec's for a 180/55 to be mounted on either rim width.
A lot of us on this forum run a 190/55 for our street RC51's. They're great on a track too.
Stock size is 190/50-17.
The 55 series is a taller tire with a bigger contact patch at lean angles, and makes tipping into a turn easier and quicker.
190/55 is a great size, thats what I run. Ive never run a 180/55 but it looks very similar, but like jondog said, the rim size is more conducive to a 190 width. All the cool kids run 190/55!
JD is right, most people that mount the 180/55 do it to save money because they go through tires much faster at the track. It gives you a taller profile for a slightly cheaper price, but I think the overall contact patch is not as big the 190/55.
For regular riding the stock 190/50 is fine. I'm still running 190/50 on my SP2 even at the track (since the tires were new and I didn't feel like spending the money right away to change) and I have no problems. Next summer when I need to replace I will go back to a 190/55.
Some people even run a 200 size.
200 is stock on a HP4 (not an RC I know)...but just saying that there are different combinations on what you want to do based on your riding style.
Search is your friend. This has been discussed, and discussed, and discussed, and discussed, and discussed,........
I run the 190/50.
So will I have fitment issues with a new chain running a 190/55?
My is at the end of its life cycle. I would hate to buy new tires and chain and sprockets and they not fit :eek:
Your swingarm is rounded on the SP2. The SP1 is squared.
I think you guys have a little more clearance.
I think I'll try the 190/55 anyway...
I run the 190/50.
Cool thanks. I bought a 190/55
You may need to add 1 link over stock length:
SP2 = 106 links
SP1 = 104 links
I had to increase my chain to 106 on my SP1 to keep the 190/55 from being too close to the swinger. When you combine the taller tire with a bigger rear sprocket -which is 42 tooth in my case- you can run out of room with the stock length chain.
Buy a chain that's not precut. DID usually gives you 120 links to work with - so just cut to fit.
1 - 18 of 18 Posts
