Hello. Since it is an early injector, it does not have a correction function, and even if you set it strictly, it will be set out depending on the temperature (as you know, it is so nervous that you need to set it just by changing the tailpiece).
Therefore, even after having the dynamo adjusted at the shop, it is good to run while checking the rotation speed with a digital tachometer and monitoring the throttle opening with equipment that can see the throttle opening.
This way, if you feel sick, you can modify and switch the Powercommander map for its opening and revs yourself.
You can simply pursue the A / F ratio, but in the case of RC51, the range of around 2500 rpm & throttle opening 2 to 5% is difficult, so if you set this to the ideal A / F ratio, when the accelerator is slightly closed I have symptoms of stalling (that is, the gas is thin).
At Honda, the A / F in this area is thickened to relieve the symptoms, so fuel efficiency is poor :'(
The map switching function of PCV is convenient, and in Japan, where there is a lot of traffic and fuel efficiency is always poor, there are many users who switch between a thin map and a normal thick map.
For your reference.
