ok, well to start off this issue is completely my fault. i was wiring up my undertail and had everything together ready to cover up all the open connections. Turned on the power to make sure everything was wired properly when two connections touched and shorted itself out. i know, stupid mistake. covered and cleaned everything up only issue is top portion of my cluster does not work now, only the bottom portion(signal, high beams, and rest of smaller lights still work). the rear signals and brake lights work fine, running lights do not. Pretty sure i blew a fuse/ relay. any ideas which one?
