1 - 18 of 18 Posts
Alright guys, I think from the day I got my RC I have searched over heating things, and Ive got the basics covered.
I guess I am posting just cause I want more peace of mind.
So when I got my Rc, It was fine because it was a bit cooler out.
Now that we are starting to get some 80 degree days it has been a bit different.
first issue:
Riding one day and seemingly running extra warm (240deg)
A bit more in town cruising and BING 255! I immediately pull over and let her cool down.
Then I head home about 3 miles away and as I am pulling up 255 again!
SHIT. So I pull the fairings off to inspect, and I notice I am significantly low on coolant, which is somewhat of a relief cause I know thats why I am over heating. But now wondering where my coolant has gone, as there is zero signs of a head gasket problem, and no leakage....
Anywho, top it off she runs well right around 200-210 maybe 220 at times.
Seems to confirm all ive read.
then a week later, I am riding and I see temps creeping back up to 230 area and then even back up to 240.... WTF
So I head home and notice a decent leak coming from underneath the bike.
Pull the fairings again, and notice a gian glob of JB weld stuck to the radiator that I must have not noticed before.
Pull the radiator, scrape away all the JB weld, found the small hairline crack in the runner they tried to repair. Opened it up, used some aluminum brazing on her and sealed her up shut!
Topped it back off with coolant. and right at 180 she stayed, and of course the occasional 200-215 in traffic.
Seems to be all well, no leaks decent temp etc.
NOW yesterday was about 85 degrees, I was out riding and she got up to 225 and when I got moving she started to slowly crawl back down to 218 220 when the fans kicked on at a stop she stayed right there or at least VERY slowly increased.
Then hovered around 220-225 while cruising in 35 mph traffic and stop lights people in front of me etc.
I assumed this was pretty normal for how warm it was outside and the traffic I was in with stopping etc.
Well this morning it was about 60 degrees, I got about 3 blocks from home and she was already at 175,
Then another mile or so Im at 210, then by the time I am about 5 miles out Im already at 220. Its still only 62 degrees out or so, and not much traffic was about 7am.
This morning in the 60 deg temps, she never went over 220.
So heres my thing.
Someone tell me this is normal so I stop being paranoid. hahaha
It seems she is VERY quick to warm up, and VERY quick to get to 220.
When its HOT out she can still manage to stay around that 225 area comfortably and when I get moving with no one in front of me she cools down properly and sits around 220 ish.
I am afraid that maybe I didnt get the leak sealed all the way and the more I ride I may be loosing a tiny bit of coolant as it kind of seems like she is getting up to temp a bit quicker now.
I have to make a 1.5 hour (one way) ride tomorrow, and I am just a bit nervous.
I am going to check the coolant levels tonight after work to make sure I am still good to go.
But I guess I am just looking for some seasoned RC owners to chirp in and tell me:
Yes: It only takes a few mins to get up to a normal temp while riding.
Yes: it is normal in warm weather to rest around 215-230 while in rural traffic settings.
Yes: even in 60 degree temps the bike SHOULD reach and maintain 220 deg.
I may be just paranoid but my baby has 30k miles or so, and I know heat kills motors I want to make sure she is good.
Thanks in advance guys.
Anything over 224° is pretty concerning on an RC51 in motion let alone in heavy traffic. Over 240° and you are looking at head warpage...
You have likely blown a headgasket and the coolant is leaking into the exhaust and being steamed out of the tailpipes.
I highly doubt I have a head gasker problem. I have literally zero signs of that (milky oil, bubbles in coolant, misfires) the only reaaon i lost coolant before was obviously the leak I later discovered, it has since been repaired, and to my knowledge I have not lost any more coolant.. so that would be a pretty drastic assumption on the head gasket..
Numerous forums state 220-225/230 is normal when stuck in traffic on a 85 degree day. Im looking for more first hand experience from seasoned rc riders on the temps they see.
Just a simple google search tells me it is but may be a tad warm.
Like I said, I get movinf past 45mph and all is well, it was almost 90 degrees out and 30 mins of riding in stop and go less than 35mph im really hoping to hear this is normal first hand instead of reading 5 year old threads on other forums
On a 100° day in nasty humid Memphis where you sweat just sitting in the shade my RC's in traffic would sometimes briefly hit 228 before the single fan would cool it back down to around 218-220. If either of the bikes were in motion even just 10-15mph the temp would rarely get over 204 and even on the race track on 100+ degree days I would rarely get over 200° at full pace and no fans installed at all.
I cannot ever recall hitting 230° on any of the RC51's I have routinely ridden which are fairly numerous including the one with High Compression Pistons that did tend run a bit hotter than the others.
Well there is a ton of threads out there saying what I am, but that being said im still here asking cause I agree all my experience on bikes 225-230 on an 80 deg day just dossnt seem righr to me my old 08 1000rr would see 220 on 105 degree days.
I just checked and my coolant is completely full just as it was the last time I filled it. So now im at a loss.
Now I let it idle sitting here and it slowly starts creeping up to 220 the fans come on ans it drops to 219 then extremely slowly keeps climbing I shut it off whenit got to 225. Fans work, coolant is new and level is fine. Wth could this be
I burped it prettt well when i repaired the crack, let it run with the cap off to 205deg blipped the throttle then topped it off. I just burped it again, and while I was into it I pulled the left fan off, and quick fabbed up a rad scoop out of sheet aluminum.
I just took it for a spin and in the first 2 miles it struggled to get over 175 bounced between 160-170 a bit. Then at the first stop light it slowly got up to 210 this was a long light so I shut the bike off, kept riding and held steady aroubd 210-215, came to a stop ans let it idle got up to 218, then as soon as I started moving righr back down to 210-205.
And thats really it. Still bugs me how it wants to keep climbing temps at idle. Wonder if my fan (s) are getting week.
I figure id rather run 1 fan and be able to shut the bike off at idle to gain the air flow and now new cooling ability from my home made scoop.
The prior owner on mine sealed puncture on the left radiator with JB weld, which of coarse didn't hold and started leaking.
I pulled the radiator and had the pucture heliarc welded and pressure tested.
Since then, the warmest it has gotten is 221 degrees on hot Florida summer day in traffic. The fans quickly cool it down to 218.
Once moving, the temps then drop to 205-208, and lower when freeway speeds are reached.
Therefore, I've got to say you still have a cooling issue somewhere.
http://www.fireblades.org/forums/honda-rc51/58180-what-should-temperature-my-rc51-reading-normally.html
http://www.rc51forums.com/forums/showthread.php?t=5771
http://www.speedzilla.com/forums/honda-rc51/19665-normal-operating-temperature.html
http://www.superhawkforum.com/forums/technical-discussion-28/01-models-average-running-temp-20178/
http://www.centralvalleyriders.com/forums/archive/index.php/t-13708.html
So there is about 15 people who claim they regularly hit 220-230 on hot days....
What do you guys have done or where do you live that you never have these issues?
Hahahah
I am going nuts trying to figure this out.
Obviously if my bike runs for hours and the fans never even come on I think its safe to say I do not have a cooling problem.... lol
However I don't think its normal to hit 225+ on a 85 degree day, I also believe honda did not design a bike that would overheat at idle on a hot day.
Doesnt make any sesne to me. Something isnt right, but I dont think something is exactly "broken" now.
So help me out,
my fans work as well as the temp switch, there is no air in the coolant, the coolant is new, the hoses are fine, there is no leaks, while going 30mph+ there is no cooling issue at all, regardless if it may be a bit warmer than yours.
What I am seeing is confirmed by a ton of people as I am searching.
what are your thoughts??!!
As much as I think it can be with the cap off the coolant starts to move around 180 then really starts flowing around 203
But I think I found the problem. I am running straight coolant concemtrate and apparantly thats shitty at transfering heat and will cause it to run warmer it still "works" but just not that well.
Time to flush. Im sure thats it
Well glad to know it's not an actual problem with the bike, but merely that you are inept at being a basic mechanic.
Did you even bother to use silicate free glycol or did you just dump automotive grade anti-freeze into your cooling system?
Discussion Starter #15
Whoa no need to be a cunt there guy.
Ive actually been a mechanic half my life. That being said, i dont have a lot of experience working too deeply on motorcycles.
My local bike shop (the owner is a certidified kawi tuner, raced for a very long time, and owns a tl1000r) sold me the coolant, also when I decided to use straight coolant I did so because the temp threshold is much higher. That being said im a nuts and bolts guy, never in my years have I worked on something that I had to worry about the heat transferability within a 15deg range.
So in short, yeap I fucked up. Whoops
Am I an inept basic mechanic? I dont know id go as far to say that ive been working on things for years and built numerous cars including a 700hp rx7, and an e85 500hp Nissan 350, oh and my current 350hp e46 m3...
But since i goofed up on the coolant for my bike and you want to be a dick head to a stranger on a forum looking for help. But if it makes you feel better thats fine. Call it what you will.
Years of experience, been a mechanic half your life and yet you still don't know that you are supposed to dilute anti-freeze concentrate :rolleyes:
Discussion Starter #17
I think your issue here is you are thinking that I didnt know anti freeze is supposed to be diluted. I learned that when I was 10 years old from my dad.
As I said, I chose to add straight antifreeze because I knew it would have a higher temp threshold of something like 270deg. Since I did this when my bike was regularly hitting 235-240 and a 50/50 mix does not withstand much higher than that I thought it wouldnt :hurt: to use straight coolant. Again if you read I said ive never had to work on something so precise in temp.
So if youre done insulting strangers id like to let this thread die. Thanks
Concentrated Glycol will have a higher boiling point than water alone, but will not allow for better cooling effect as it retains the heat in the thicker fluid.
1 - 18 of 18 Posts
