1 - 11 of 11 Posts
this is why I love doing all my own work, was changing the oil and cleaning the under side a bit and found a small crack in the front cylinder header. Can i weld it up or do i have to get a new header all together?? Hoping I'll be able to weld it just need some advice first...........thanks.
James
close to were it's bolted in but it's down about an inch or 2
Discussion Starter · #5 ·
ok, my dad has both.................Have to make a trip back to NC to get it done one of these days, not sure of the cons of riding with it like that, do you know what they would be??
At worse, the crack would propagate and the tubing could separate from the flange.
That section gets hot and expands and contracts a bit, plus the vibration.
I would try to get it welded as soon as possible just to be sure.
+1 try to get it repaired as soon as you can
Discussion Starter · #8 ·
cool, will get it repaired asap.........thanks guys
Discussion Starter · #9 ·
pics of the crack:
Hopefully getting it welded today!
Hello,
If its not to late and you are tig welding the crack purge the inside of the pipe this will give you a better quality weld as the inside of the pipe/weld will be protected by the sheilding gas the same as the out side.
1 - 11 of 11 Posts
