1 - 12 of 12 Posts
So as some of you know not long after getting my bike the counter shaft bearing went out in my tranny. So after tearing down my whole engine and lots of help from Ben (rc51parts.com) she back together now and im taking baby steps to make sure everything is working ok. I must say that I love the way this bike runs and sounds and it was actually a lot of fun doing all the work on the bike. So far the bike hasn't been ridden real far, but holds a steady temp of 73* c (is this about normal?).
Now that being said after further examining of the bike I was wondering are fully adjustable front and rear shocks a stock component of the bikes. Also, the bike has a full 2into1 yoshi exhaust and that being said has anybody experienced any draw backs to full exhaust systems? The reason I ask is because the bike pulls like a mad monster, but.... once in sixth gear the bike doesn't like to cruise at a steady speed. Is this due to not enough back pressure from the full exhaust? Now I have noticed in tearing down the bike that some mods have been made (some I haven't the slightest idea). For example, I have a plug in the wiring harness that has two wires (green) soldered together under the fuel tank among other stuff. Also I noticed from looking at the manual im missing the air guide plate for the front of the motor.
I don't have a pc3 or aftermarket airbox or filters. The bike was most likely a race bike because its covered in race rairings.
Sorry for the long read but I just wanted to inform everybody of my progress.
Just glad you got it back running....now let her go eat once you feel comfortable. 163 degrees F isn't bad. These bike run on the warm side usually. I use Engine Ice to keep mine cooler.
Sent from my Motorcycle iPhone app
Thanks. Im excited to get her out and stretch her legs.
As a side note, the exhaust is a 2 into 1 Jardine, but with a Yoshimura muffler.
It's how mine came when I bought it.
When I first got my bike, the mapping on the PCIIIr was totally whacked.
It was so lean at 5800 RPM, the power fell right off and it would start misfiring.
I got it remapped and everything was fine afterwards.
Thanks, thats actually good to know.
I think with the full exhaust thou it lacks the required back pressure for a lot of cruising. I had the same problem on my cbr954 when i had a full exhaust on it after deleting the hvac system.
Oh wow this is good reading. Thanks for the update and the pic of the bike your right it does have race fairings on it. Well being a new owner of a rc51 and having to do what you went thru shows a passion for the ride. Now as far as the temp goes on your bike the others that posted are correct they do run on the warm side. I'm in las Vegas and my bike can be normal at 220*f. Now don't feel so bad because we all go thru some sort of problem with our bikes. Like right now I'm dealing with Honda with trying to warranty my fuel tank that's leaking and they are pisssing me the [email protected]@@ off. But that's my issue. On the flip side Honda of America did say they are will to cover half the cost of the tank. But I'm trying to get it all covered. But I will tell you what bro everything we do for our bikes to keep them going and looking good is awesome the reward is on the road or track these bikes are truly in a class of there own. I'm looking to buy a 2nd rc51 now I'm looking for a sp2 i want to have both models I know there are a few changes but having both would just be awesome. Anyways I'm getting a little winded here. Good job bro its nice to see a fellow like minded person bring back one from the dead.
163 is kinda low actually. It doesn't get any higher just idling?
I think the thermostat is supposed to open at 174 or something like that. It sounds like yours is stuck open.
I will say the other day it actually got up to 75*c, but I've had to work on her since pretty much the day I got her lol. Is it possible that the previous owner could take out the thermostat completely like they use to do in older vehicles when the thermostats would go out instead of replacing them? But I haven't ridden her much plus I live in the country so I don't see a bunch of stop and go traffic which may help her stay cool.
I love riding and I was so excited the day when I got her because I have always wanted an rc51. So im willing to do what ever work is required and besides I love working on stuff so its a win/win for me.
Thanks to everybody for your input and advise.
163 is kinda low actually. It doesn't get any higher just idling?I think the thermostat is supposed to open at 174 or something like that. It sounds like yours is stuck open.
I agree. According to what I can remember from the manual, the thermostat will begin to open at 167. It's fully open at 174. When the outdoors temperature is around 50 to 60 degrees F. and about 35 to 40% humidity, my bike will warm up to about ~185 at an idle, before I go riding and put any load on the engine.
When I first read the initial post I thought that sounded a few degrees to cool. From what I understand, you should be running at least 180 - 190 for the optimum performance from the factory fuel map, and up to ~220F. Seriously, get a powercommander and a decent map for that full exhaust. Cause you can bet your current factory fuel map is all wrong for the full exhaust system you have.
By now you've figured out to check the thermstat, Cause unless it's real cold in your garage, I think you're temp should reach a little higher.
Yeah, I thought it was kind of cool as well, especially after reading the manual to see what was correct. I normally allow the ole girl to warm up as well because I believe that the amount of time it takes to fully warm up allows plenty of oil to reach the entire engine.
I definently plan on getting a pc among plenty of other stuff. I am talking to Ben (rc51parts) right now because I want to either swap or buy another speedo because my current is a single mode and I would like it to read in mph and *f.
I currently have not checked the thermostat but that's only because I have been working a lot lately. But as soon as I get a moment ill open the ole girl up again to check it.
Just a little update: I took the bike for a ride today and as I said previously each ride would be longer and more stop and go. So anyways, I got going and being the dummy that I am I forgot to put the exhaust retaining spring back on and half way down the road my exhaust came loose on one of the headers so I got her back home and let her cool down and got the spring installed.
After that I took her for a good ride and everybody will be happy to know that the engine temp did get up to 77*c and 80*c sitting at a stop sign but cooled back down to 77-78*c after getting back going. She is running flawlessly so far, but im definitely planning on getting a power commander in the very near future.
Would anybody be interested in swapping speedo guts, because I hate not being able to switch from km/h to mph.
Again thank you everybody for your opinions and comments.
1 - 12 of 12 Posts
