I am in the process to upgrade my CBR to underslung rear bracket with 84mm P2 32 / 34 calipers. I have easy access to a company who produces this part in Italy (Styleandperformance) for SP1 but I need to clarify the compatibility with my application. Both are fitting 220mm disk and this is a big help for what concerns the location of caliper from a radial position and they share the same caliper, so a part of the game is already done. The most important dims to clarify are what is defining the offsets of the datum surfaces in the vertical plane. For this reason I have measured my OEM bracket and would appreciate if someone who has easy access to this info could share to understand if I can go ahead with the project or better "kill" (options are : 1) GO; 2) REDIRECT; 3) KILL) So here you find my "reverse engineering" sketches for my CBR bracket sorry I did not have much accurate gauging in my garage. We do not need to chase microns considering the above conditions and we can accept some kind of misalignment for the mid plane of the disk in regard to the caliper. ( fyi: Brembo calipers have 16mm offset). Surely the shaft's hole diam is different (20mm CBR vs 25 mm SP1) but this can be solved easily with press fit of 25x20x25 commercial bushing).
Geometrical compatibilty with acceptable accuracy is the first goal, then the next point is to understand how these Brembo calipers with twin pistons ( P32 mm or P34 mm can work with the Honda OEM 15.8 mm m/c which was designed to work with 1 x 38 mm cylinder. Has anybody gone through this step, what is the result and is 2x 32 mm probably a better option than 2x34mm for the 15.8mm m/c ? ?thanks
(DISCLAIMER : dimensions may have some accuracy measurement error )
