1 - 2 of 2 Posts
Would a SP1 slip-on exhaust (hindle low mount) fit after a SP2 swingarm change?
The swing-arm change would prospectively be down the road ... curious if I'd have to do a full exhaust change that point.
Thanks!
If i remember correctly, you should be fine. I know full systems are good to go and as far as a slip on goes on an SP1 with an SP2 swingarm you can can still run the SP1 slip on as long as you keep the SP1 header.
I had a full SP1 system on mine with the SP2 swingarm with no clearance issues.
1 - 2 of 2 Posts
