I believe it might be possible.
However, you will probably also need the SP2 adjust case.
The adjust case on the SP2 has a square outline that rotates the adjust plate.
Out of curiosity, why are you considering this?
The SP1 fork bolt has fewer parts than the SP2.
Here's the SP1 fork bolt and adjust case assembly
Here's the SP2 fork bolt and adjust case assembly
Thanks for the information. Looks like it'll be a little more costly than I expected. $300+ for new dampers. Ouch. The only reason I wanted to switch them out was because of looks. I think the SP2 adjusters look much better and cleaner.
