Hi Guys,
i have sound coming out of the clutch housing / CLUTCH BASKET, i checked with a local dealer and he only has SP2 clutch basket available..
can you guys confirm if i can use SP2 Clutch housing on SP1 ?
what about the Clutch cover GASKET can this also be used from SP2 ?..
Cheers. Sam.
SP1 and SP2 clutch baskets are the same.
Clutch cover is the same.
Clutch cover gasket is a molded O-ring type design that can be reused. The cover has several molded areas that makes it easier to hold the gasket in place.
