1 - 1 of 1 Posts
I have a problem with the Dim switch whereby it now sticks in the "in" position (lights full-beam). With repeated pressing the switch will eventually pop out. I have given it a good soaking with WD40 and that has freed things up a bit, but I wonder if anyone knows how to take this apart? I have the full factory manual and the disassembly of the left-hand switch gear is not covered. I can see that the switch gear can be unclamped/removed from the handle bar, but I've not done that yet.
I assume there is a spring inside the switch and that it either needs replacing or packing with grease? (WD40 is never a longterm solution in my experience). Any help appreciated thanks.
1 - 1 of 1 Posts
