yes, send me a pmStill have the passenger seat and under tail?
sorry i dont have the guages, and the snorkel i do have has the gauge mounts brokeni'm looking for the air intake snorkle and gauges
can you send some pics of the snorkel and how much?sorry i dont have the guages, and the snorkel i do have has the gauge mounts broken
send me a pm with your email? ican you send some pics of the snorkel and how much?
OEM CDI | $ 325.00 |
Looking for a V-fairing and a clutch reservoir. Hit me up?putting this one out to pasture, only 8702 miles on this stuff.
prices+shipping atlanta
OEM SP2 Mainframe SOLD sp2 swingarm/ caliper bracket, hardware etc (one mount broken, needs a refinish) SOLD OEM SP2 Undertail w/LED brake light SOLD OEM sp2 subframe straight $ 375.00 Sp2 radiators-$75/ea $125 pair (not mint, but hold pressure fine) SOLD OEM SP2 rear wheel $ 250.00 OEM magnesium rear Valve Cover (each) $ 50.00 OEM Sp2 forks *needs seals but straight $ 600.00 OEM sp2 front brake calipers $ 135.00 OEM front Seat $ 130.00 OEM Passenger pegs (right side tweaked) $ SOLD OEM Turn Signal/Horn control $ 60.00 OEM Killswitch $ 40.00 OEM Passenger seat $ 150.00 OEM clipons pair L/R $ 40.00 Sp2 chain guard OEM $40 OEM CDI SOLD OEM Rectifier $ 75.00 OEM sp2 Ecu SOLD OEM font headlight wiring harness $ 100.00 Sp2 Main Wiring harness $ 220.00 sp2 rear wiring harness (turn signals/brake lights need to be redone) $ 220.00 OEM Tank (left side rashed/dented) $ 250.00 OEM Fuel Pump Assembly SOLD Jardine 2>1 damaged SOLD Dynojet PC3r SOLD OEM SP2 Lower/Upper Triple Tree (straight) $400.00
sorry, i dont have the V fairing, and the clutch res. is cheap enough from Honda (~$30) its not even worth a trip to the post office aloneLooking for a V-fairing and a clutch reservoir. Hit me up?
Still have the tank? Im in atlanta
yea pm meStill have the tank? Im in atlanta
Hello...., I am just reaching out to you to see if you might have any front seat bolts for sale? I removed the seat on my RC last month to service my battery and mis-placed the 2 10mm seat bolts. Can't believe I did that!! Can you help me? Shipping would be to Cali 93314. Thanks, Will [email protected].putting this one out to pasture, only 8702 miles on this stuff.
OEM SP2 Mainframe SOLD sp2 swingarm/ caliper bracket, hardware etc (one mount broken, needs a refinish) SOLD OEM SP2 Undertail w/LED brake light SOLD OEM sp2 subframe straight $ 450.00 Sp2 radiators-$75/ea $125 pair (not mint, but hold pressure fine) SOLD OEM SP2 rear wheel (slight bend on lip, still rode straight) $ OBO OEM magnesium rear Valve Cover (each) $ 50.00 OEM Sp2 forks *needs seals but straight $ 600.00 OEM sp2 front brake calipers $ 150.00 OEM front Seat $ 130.00 OEM Passenger pegs (right side tweaked) $ SOLD OEM Turn Signal/Horn control $ 70.00 OEM Killswitch $ 40.00 OEM Passenger seat $ 150.00 OEM clipons pair L/R $ 40.00 Sp2 chain guard OEM $40 OEM CDI SOLD OEM Rectifier $ 75.00 OEM sp2 Ecu SOLD OEM font headlight wiring harness $ 100.00 Sp2 Main Wiring harness $ 220.00 sp2 rear wiring harness (turn signals/brake lights need to be redone) $ 220.00 OEM Tank (rashed/dented) $ 350.00 OEM Fuel Pump Assembly $ 350.00 Jardine 2>1 damaged SOLD Dynojet PC3r SOLD OEM SP2 Lower/Upper Triple Tree (straight) $400.00
I need front valve cover. Please let me know.putting this one out to pasture, only 8702 miles on this stuff.
