1 - 11 of 11 Posts
Hello again all.
So I had a serious malfunction on my 05 SP2 today, in the middle of swift moving traffic, part way through a 268mile trip from NH to NY.
The bike showed no signs of loss of power through the trip, and around a lazy turn, the engine just quits. All the electronics stay on, but the motor just stopped. When I pulled over, I immediately switched off the bike and checked for leaks, smoke, or any signs as to what happened. Nothing. No overheating. No leaks. So I give it time to cool down anyways and when I try to start it, the injectors prime, the lights go through the proper sequencing, but the low oil pressure light stays on and begins to flash. The engine turns over confidently but doesn't start. Just cranks over. I tried switching the engine stop on and off and trying again but no luck. I eventually gave up and had it towed to a dealer.
Bike has just had an oil and filter change prior to the trip and electrically and mechanically had been operating fine. When I checked the oil level it was a bit higher then recommended filling the entire oil check glass when the bike is stood upright.
I am sorry for the long exposition but just trying to provide as much info as possible. The bike is being looked over as i stated above so I will post the findings but has anyone ever had this happen to them? Or know what the hell happened?
Thanks for all responses and views.
Did you check your fuses as well prior to having it towed?
Always a good idea to check a few of the key fuses (ie starter/fuel pump/main fuses, etc) and bring along some extra fuses during road trips. :)
FWIW your oil pressure "warning light" appears to be working as it should (in a nutshell - it will stay lighted prior to moving the key to the "start" position and rapidly flash as the bike attempts to turn over until the oil pressure sensor/circuitry senses the minium amount of oil psi required to keep things happy).
Out of gas? Fuel light out?
Longshot, but did you try opening your gas cap to see if there was a vacuum in the tank? pinched off vent line?
@cobra, That would have been a good idea. I unfortunately didn't have any tools with me to even remove the fairing to access the fuse area. In the future I will absolutely keep some fuses with me and some basic tools so I can check over that possibility as well.
On your second point, would the oil pressure sensor not allow the engine to turn on in a low oil situation?
@David, I forgot to mention that. I do have a PCIII on the bike that was installed prior to my taking ownership. The bike has a Akrapovic exhaust, Power Commander 3, Sprocket kit (not sure the teeth count), it also has what looks like some vacuum lines under the instrument cluster that have been disconnected and plugged. I think this is called a "flapper mod"... please apologize my ignorance as I am not very well versed on even the more common modifications.
So if a specific fuse goes out, the bike will shut off? This seems incredibly dangerous. Not to cry or anything, but I very easily could have been injured or killed as a result of this malfunction but I guess it can happen to all bikes. I am so disheartened by this issue as my RC had never given me problems before and it is my dream bike ='(
**Edit: Plenty of gas, I get anywhere from 100-120 miles per tank before the light pops and I was refilling every 70-90 miles .
As far as the vent line, I am not well versed enough in the bike design or general mechanical ability to have checked this possibility.
Thank you for all the responses!
**UPDATE**
So I just heard back from the shop.
No spark at all. They are suggesting it is an issue with the CDI module.
I am off to research what that is, and how cheap I can find one because they quoted me a $500.00+ price tag on just the part.
Any ideas how to proceed aside from the above?
Thanks for all the responses guys. ---> Added a photo of my girl... :(
Going out on a limb here but I would check the bank angle sensor. That is supposed to cut the motor in the event of a fall.
I have heard of other Hondas having an issue with this failure.
CDI units generally don't fail unless there is a spike in the electrical system or a short of some sort.
I would also check all the electrical connections, corrosion inside on the terminals plays havoc with ECU controlled bikes.
However having said that you say it is at the Dealer so I would assume that they can do proper diagnostics.
I would be interested to hear what it is.
I you really need a new CDI, I have a spare brand new one I could sell to you (Which I bought when I had CDI problems - eventually traced to some bad wiring a previous owner had done, where a spark could jump between terminals and fry the CDI unit!).
$500 doesn't sound bad, I'm pretty sure that's what I paid a few years ago... 4 times - till I eventually found the fault (Even the Honda dealer didn't find the cause, they just replaced the CDI!)
I'd check fuses first, but doesn't sound as if that's the problem as any bike shop that didn't realise it was the main fuse wouldn't still be in the business of repairing bikes!
Thanks Stig. I bought what was advertised as a CDI on Ebay and had it shipped there and wouldn`t you know it, they sent the wrong part. Crazy. I ended up just giving them the go ahead with the new CDI.
I just got the bike home today. $1003.00 bill which isnt the worst bill I have gotten so I gratefully paid and took the bike home this morning.
Essentially there was something up with the front spark plug and the wire not being connected properly... something like that. Long story short the thing was arching all over the place and it shorted the CDI so I am hopeful that the cause is dealt with and not just the symptom. Time will tell tho.
They replaced the CDI, spark plugs, and battery.
Thank you guys for all your help and suggestions!
1 - 11 of 11 Posts
