Hi,
Does anyone know if there is a fuse panel for the Speedo Cluster ? Mine has burned out and I want to see if it could be a fuse issue before buying a new one. Reason I am thinking fuse is the turn indicator lamp on the gauge works, but not the others....help ?
its on left side of bike under the tank and above the coolant overflow bottle. you have to take off the left side fairing in order to get to it. its a 10amp fuse bro. sounds like it might be the gauge though. if its a fuse, usually the entire speedo wont work. good luck, ken
Thanks...will take a look at it when I get home !
Thanks gang...it was a fuse ! Replaced it and all is well ...
