I've installed a HealTech speedo healer two weeks ago. Does the healer come in the mph version when installed? I have been setting my speed with a gps and I've set the unit at -13.5. If I want to set km/h, do I set -74.4 for km/h?
Thanks
Here you go
Press SEL until the actual mode ([C] or [-]) is displayed and keep it depressed for one more sec, until the value switches. When Km/h to MPH conversion is active, the indicated speed and distance travelled will be converted, but the displayed units of measure (km/h and km) won't be changed. It is possible to switch on/off the Km/h to MPH conversion only. If you wish to use MPH to Km/h conversion, you have to program +60.9% (1.609 multiplier) on top of the calibration value you need. However, keep in mind that your speedometer’s maximum reading will not be changed. E.g. a speedo with 186 MPH highest reading will not be able to show over 186 Km/h after conversion.
SpeedoHealer calibration
The above response is the correct HealTech fix I suppose. However, couldn't you simply change your Honda speedo from MPH to KPH using the built in switch. In MPH mode simply hold down the toggle button for a couple of seconds and disply changes from MPH to KPH. Isn't this simpler?
Good to go! Got the exact calibration with the GPS with no error. At least no error more than 0.001%
