Just got my bike back from having the fork seals replaced now speedo and odometer doesn't work. Checked fuses and all are good. Called my repair guy he said speedo was working when he test drove the bike. Anyone have any ideas on the fix?
If the panel works ok and just doesn't register any speed, then the speedo sensor or connector is probably the the fault.
The speedo sensor is located at the rear of the engine towards the right swingarm pivot.
You'll see a wire going to it. It bolts into the rear of the engine.
It's a bit snug with the rear exhaust pipe in the way, but not too difficult to replace.
Thanks will check that out to see if it solves the problem.
