1 - 18 of 18 Posts
today i took the sp1 out for a spin and i'm suprised at the speedo readings
i can easily be doing an indicated 100mph and it feel like 60 mph, friday i took my buell 1125r out and while it may accelerate harder at 90mph i'm getting buffeted which i don't get on the sp1
are the sp1 aerodynamics that superior to the buell?
what should the stock sprocket sizes be? could that give me a different speedo reading?
The stock sprocket sizes are 16/40 and it definitely feels different if you change them.
If you have a 15 at the front and/or a 43/42 at the rear, then the feeling you get is quite right.
All you need is a speedohealer so that your dash reading reflect the speed you're feeling riding at.
just had a quick look and the rear sprocket is a 40t so i'm guessing without looking at the front its running stock
maybe honda's 2001 aero's are far superior to 2008 buells:)
There are still a lot of things on the RC far superior than just about any Buell, aeros is just one of them.
Yes
Yes they are. Buells are meant to cruise and corner with a top speed of what 130. RC with racing aero and a top speed of 170.
I commute on a '08 xb12r and with the stock windscreen @ 70 mph I had to pull myself forward with the wind blowing right on my face shoulders. It's a workout.
I've since put a double bubble on her and it is much nicer. I still get wind on my helmet but I'm not straining my neck. and can now ride with one hand up to around 85-90 instead of 65-70 with the stock screen.
I can cruise at 100 on the rc with one hand on the bars and my 04 r1 was the same as the rc
What do you think of this?
My theory; which could be proven or dis-proven with a little mathmatics.
190/50 tire with 15/40 sprockets is equal to 190/55 tire with 15/42 sprockets in terms of final gearing.
Am i thinking right?
Nah
You only have about a 3% difference going from 50 to a 55 tire which is
It's equivalent to a -1 or -2 rear sprocket change
Going from 16/40 to 15/42 is a 12% change
Nah
Take 16 out of this conversation. We're only talking about the rear sprocket and tire. Given a 15 up front.
Ok, so a 190/55 will only travel 3% farther than a 190/50? That doesn't sound right...
What's the difference in percentage going from 40 to 42? All other things the same.
15/40 is 6.67% lower then stock
15/42 is 12% lower
So about 5.5% difference
A tire change being 3% it would be close.
I'm using this calculator http://www.gearingcommander.com/
1 - 18 of 18 Posts
