I have the 2000 model SP-1 which comes with a 104 link chain. I ordered a chain and sprocket set changing stock gearing from 16/40 to 16/42 and I believe they upped the chain length to 106 links. Will the rear wheel sitting deeper on the swing arm cause issues?
Thanks
If your new chain has been lengthened by a couple of links, then it will compensate for your larger sprocket. So your wheel should sit close to where it was at when it was 16/40.
I need to run 106 links on my SP1.
15/42 and a tall tire - 190/55 or 200/55 - was a little too much for 104 links.
You run a 200/55 tire? Do you have to change the rear wheel for that or can you use the stock wheel?
