· Registered
Guys, need help here regarding sprocket set up...i intend to change to 15/42 sprocket...but if i do conversion 520 chain....it will damage faster then 530?? Here, in Spore i asked the mechanic & they advised me it better to used 530 as it will not damaged the chain due the Rc51 is very torque...is it true?...
· Senior Member '09 Dec BOTM
The torque is high.
520 is good only for racetrack.
I have chosen 525 "AFAM" chain with 15/41.
Das Drehmoment ist hoch.
520 ist nur für Rennstrecke gut.
Ich habe 525 "AFAM"-Kette mit 15/41 gewählt.
· Registered
Discussion Starter · #4 ·
ok, i seldom ride this bike..mostly for trackdays usage & highway ride to Sepang..
Is there any feeling different 520 & 530 set up when u crank up the trottle(full trottle)?...
· Premium Member
The 520 chain is a bit lighter than a 530 (my 530 chain weighed 4 Lbs), so it may accelerate a little quicker (less mass).
Otherwise there should be no difference.
· Registered
Discussion Starter · #6 ·
well i changed my sprocket....16/42 Afam & 530 chain...& fix gear indicator
