1 - 20 of 29 Posts
2 questions lads:
1:is it the same tool for the sp1 and sp1 swingarm?
2:i found a good uk site that does these tools at a good price. trouble is that they seem to do every honda except mine. is there another bike or honda that has the same fitments? a tool that fits another bike but will also be compatible with the rc51
SP1 and SP2, both are fine. Also works on 04-07 1000RR Fireblades.
Do you already have the engine hanger adjust bolt special tool?
When removing the swingarm, you must follow the sequence for loosening certain engine mount bolts in order as well.
sorry sub, i misunderstood what you meant.
anyway, closer to the time (dec) ill have to get how of a "how to" on removing the swingarm.
and no, i dont have the tool yet
nice tool, and great price.
Since my tool ( RC51.parts multi-tool ) is already " Damaged "... I can send it to " your guy " he can make two for us.
In STAINLESS STEEL
Special tools.
The large one (07YMA-MCFA100) is for removing/installing the swingarm adjust bolt lock nut for SP1/SP2.
The small one (07VMA-MBB0101) is for removing/installing the engine mount adjust bolt lock nuts for the SP1.
Dimensions on the swingarm tool:
Length overall: 100 mm (although I felt it should be shorter)
O.D. at lock nut end: 45 mm
I.D. at lock nut end: 36 mm
Wall thickness: 5 mm
Width of each lock nut tip: 6 mm
Height of each lock nut tip: 4 mm
Distance from 3/8" drive center to tool center: 50 mm
Dimensions on engine adjust bolt lock nut tool:
Length overall: 70 mm (although I felt it should be shorter)
O.D. at lock nut end: 25 mm
I.D. at lock nut end: 20.5 mm
Wall thickness: 2 mm
Width of each lock nut tip: 5 mm
Height of each lock nut tip: 3.5 mm
1 - 20 of 29 Posts
